Hi All,
We did some customization on this form but can’t locate where this is located for us to apply the customization.
Please help.
Hello @chemuelmardie,
When there is a subform customization, you need to create another customization (even with nothing in it) with the EXACT same customization name on the calling form. The customization name is then passed through to the subform.
Mark
If it’s a kinetic application layer, make sure that you publish it.
If you’re not seeing it when trying to customize it further, choose the change layer option. Sometimes, I’ve seen this needed even if it looks like the layer is active with the name showing.
If your menu is configured correctly, it should show up if you publish it.
