Looking to pass terms code as an API parameter. It works fine if it is just letters and numbers (e.g. N30), but when the terms code has the % (e.g. 2%30, which passes encoded as 2%2530).
Here is an example if you’d like to see what I’m doing.
//// this is hypothetical for demo purposes, my code runs correctly without special characters
var auth = [YourAPIAuthentication];
var url = "https://[yourepicorurl]/Ice.BO.UD20Svc/UD20s";
var parameters = "(Company,Key1,Key2,Key3,Key4,Key5)";
//// In my case one of the Key's is equal to 2%30 or 2%2530
fetch( url + parameters, {
headers: {
'accept': 'application/json',
'Authorization': auth
method: 'PATCH',
body: {
CheckBox01: true,
RowMod: 'U'
I get the following response.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"/>
<title>404 - File or directory not found.</title>
<style type="text/css">
body{margin:0;font-size:.7em;font-family:Verdana, Arial, Helvetica, sans-serif;background:#EEEEEE;}
fieldset{padding:0 15px 10px 15px;}
h1{font-size:2.4em;margin:0;color:#FFF;}
h2{font-size:1.7em;margin:0;color:#CC0000;}
h3{font-size:1.2em;margin:10px 0 0 0;color:#000000;}
#header{width:96%;margin:0 0 0 0;padding:6px 2% 6px 2%;font-family:"trebuchet MS", Verdana, sans-serif;color:#FFF;
background-color:#555555;}
#content{margin:0 0 0 2%;position:relative;}
.content-container{background:#FFF;width:96%;margin-top:8px;padding:10px;position:relative;}
</style>
</head>
<body>
<div id="header"><h1>Server Error</h1></div>
<div id="content">
<div class="content-container"><fieldset>
<h2>404 - File or directory not found.</h2>
<h3>The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.</h3>
</fieldset></div>
</div>
</body>
</html>
Has anyone encountered this issue before? Any solution or suggestion is welcomed.
