Issue material that is in Inspection/DMR Status
Non-conformance ‎and DMR work on the inventory level. If you are allowing part classes to go negative, the operator could still issue material and drive a bin negative. You can prevent this by not allowing negative inventory on the part class or write a BPM to not allow an issue for a lot or SN that is in inspection or failed DMR.
Sent: Friday, May 23, 2014 3:01 PM
To: <vantage@yahoogroups.com>
Reply To: vantage@yahoogroups.com
Subject: Re: [Vantage] Issue material that is in Inspection/DMR Status
<div id="ygrps-yiv-254786084ygrp-text">
  <p>We are using the no -conformance but the operator was able to issue the material.<br>
Sent from my iPhone
On May 22, 2014, at 1:25 PM, "Miguel Santillan msantillan@...<mailto:msantillan@...> [vantage]" <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Are you using a Non-Conformance? Or are you just doing an inventory transfer to a non-nettable bin?
If you create a NC, it will move the inventory to the Inspection Processing Module and will not allow to you issue until you disposition the material.
Miguel A. Santillan
Compass Manufacturing Systems
510-661-6666 Office
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com]
Sent: Thursday, May 22, 2014 9:13 AM
To: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>
Subject: [Vantage] Issue material that is in Inspection/DMR Status
In our current process, material that has been placed on Quality hold is moved into a non-nettable bin and a separate inventory tag is printed with a hold status on it. Recently, we have found that if an operator searches for the lot, they have the capability of issuing the material.
Does anyone know is there a way in the system to stop an operator from issuing material that is in inspection or DMR status?
We are on 9.05.702A.
Deirdre Sykes
Financial Supervisor
CONFIDENTIALITY: The information contained in this email message, including any attachment(s), may be privileged and confidential and protected from disclosure. The email is not intended for transmission to, or receipt by, any unauthorized persons. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication or use of the information contained herein is strictly prohibited. If you have received this electronic mail transmission in error, please delete it from your system without copying or disseminating, and notify the sender by Reply email, so that our address record can be corrected.
</div>
Deirdre Sykes
Miguel A. Santillan
510-661-6666  Office
Deirdre Sykes
Sent from my iPhone
Miguel A. Santillan
510-661-6666 Office
Deirdre Sykes
