That certainly will work, but I wanted to be exact. I don’t want room for confusion between environments in case the items are similar. I suspect in most cases it will not be a problem though.
Hi Mark,
I made this solution for a SaaS MT client actually using the latest version of kinetic. Mind you, this is a BAQ Bpm so you make a good point. I have noticed that the Db object is not exposed to all business object name spaces.
And you’re sure it’s MT and not Dedicated Tenancy, I.E. Public Cloud?
For security reasons, MT has had no access to script blocks otherwise the developer could access any company in the tenant.
