Install 10.2.600
Yes, I believe so, but I’ve never done the Josh/Jose deployment method either, so I’m REALLY interested in what you end up doing because I’m going to need to do it before month end.
Note, I’m going to change my versioning scheme I think… The regular patch is fine, but I think I’ll bring the other two into the same scheme. I thought date would be easier to push updates, but neither have updates outside of the patch cadence any longer.
Correct if you have anything other than the point patch in there then you will want to move them over and I usually just give them the same version as the patch i’m on.
Well, I just looked in my sysconfig file in my client folder and only the ERP10.2.600.5 is listed. So, that answers that! Thanks!
Hello @chaddb
We are currently testing our upgrade from 10.1.200 to 10.2.400 so we need to do all of those steps to our client that you listed here. Did you use PowerShell or something else?
Thanks for your feedback,
Kelly
Yes - It’s done via PowerShell.
