Ohh I get it, well then u can't use BPM you need a customization. That's a
bit more involved but the basics are, add checkbox to form, on
NotifyInialize look up Part and then check the checkbox.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Jun 29, 2011 at 10:59 AM, Chris Thompson <chriselectrix@...>wrote:
> Ive tried putting a message in, but it calls as soon as you click on new
> line.
> I need it to be called as soon as the part details load in.
> Any ideas?
> From: Jose Gomez <jose@...>
> To: vantage@yahoogroups.com
> Sent: Wed, 29 June, 2011 15:39:40
> Subject: Re: [Vantage] How to display Part.Checkbox01 on Order/Quote Entry
> screen
> Did it validate correctly? Are you getting an error? Try adding a few info
> messages in your code to make sure it is being called
> {lib\PublishInfoMsg.i &InfoMsg = "'MSG ' + Part.Character04 "}.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Wed, Jun 29, 2011 at 10:34 AM, Chris Thompson <chriselectrix@...
> >wrote:
> > I tried you suggestion ...
> > SalesOrder.GetNewOrderDtl Post-Processing
> > ... and it didnt work.
> > Sent: Wed, 29 June, 2011 15:31:26
> Entry
> > screen
> > No offense man but that's not a very helpful reply.. What doesn't work?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > On Wed, Jun 29, 2011 at 10:22 AM, Chris Thompson <
> chriselectrix@...
> > >wrote:
> > > That doesnt work
> > > Sent: Wed, 29 June, 2011 15:15:12
> > Entry
> > > screen
> > > Change the method in which it is, its right on on SO.Update try post
> > > processing on GetNewOrderDtl?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > On Wed, Jun 29, 2011 at 10:13 AM, Chris Thompson <
> > chriselectrix@...
> > > >wrote:
> > > > Actually it is working but it is only displaying as the sales order
> is
> > > > saved.
> > > > How can it work so it pulls it in as soon as the part and description
> > are
> > > > loaded? rather than only loading after it is saved.
> > > > Sent: Wed, 29 June, 2011 15:02:01
> > > Entry
> > > > screen
> > > > are you suing Character01? if so change to Checkbox1 on the code. If
> > you
> > > > don't want them to modify it it needs to be made read only from
> > Extended
> > > > Properties
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@...
> > > > On Wed, Jun 29, 2011 at 10:00 AM, Chris Thompson <
> > > chriselectrix@...
> > > > >wrote:
> > > > > I think Im getting there but it isnt working yet.
> > > > > Im actually using Part.Checkbox01 on part maintenance and
> > > > > OrderDtl.Checkbox01 on
> > > > > Order Entry.
> > > > > Im not getting any errors when I validate now (retyped it rather
> than
> > > > copy
> > > > > and
> > > > > paste as it didnt pick up on copy/paste correctly).
> > > > > Ive tested it, but it doesnt populate the tick box on the sales
> order
> > > > entry
> > > > > lines screen when i add a part that has a tick on part maintenance.
> > > > > Also how can I get it so the tick box on order entry can't be
> > modified?
> > > > > Sent: Wed, 29 June, 2011 14:56:13
> Order/Quote
> > > > Entry
> > > > > screen
> > > > > LoL ok I wrote the syntax on here (email) so I didn't validate it
> > > needs
> > > > a
> > > > > peroid after the last end
> > > > > FOR EACH ttOrderDtl:
> > > > > FIND FIRST PART WHERE Part.PartNum = ttOrderDtl.PartNum NO-ERROR.
> > > > > IF AVAILABLE Part THEN DO:
> > > > > Assign ttOrderDtl.Character1=Part.Character01.
> > > > > END.
> > > > > END.
> > > > > And no you don't need to check anything and it should be Syncrnousl
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@...
> > > > > On Wed, Jun 29, 2011 at 9:48 AM, Chris Thompson <
> > > chriselectrix@...
> > > > > >wrote:
> > > > > > When I validate, I get this ...
> > > > > > The following application error was encountered:
> > > > > > ** Unable to understand after -- "END". (247)
> > > > > > ** D:\E9-TempFiles\13511518418486131471602482351942105938158158.p
> > > Could
> > > > > not
> > > > > > understand line 14. (198)
> > > > > > Also, do I need to select Call or Return?
> > > > > > Should it be synchronously or asynchronously ?
> > > > > > Should it be record nothing, record call, record call return,
> > record
> > > > > > return????
> > > > > > Thanks,
> > > > > > Sent: Wed, 29 June, 2011 14:33:48
> > Order/Quote
> > > > > Entry
> > > > > > screen
> > > > > > ALl of it goes under action - Run 4GL/ABL
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@...
> > > > > > On Wed, Jun 29, 2011 at 8:43 AM, Chris Thompson <
> > > > chriselectrix@...
> > > > > > >wrote:
> > > > > > > Which part of this goes under the conditions section and which
> > part
> > > > > goes
> > > > > > > under
> > > > > > > the actions section?
> NO-ERROR.
> > > > > > > END.
> > > > > > > END
> > > > > > > Sent: Wed, 29 June, 2011 13:39:08
> > > Order/Quote
> > > > > > Entry
> > > > > > > screen
> > > > > > > It is method directive
> > > > > > > then select the Sales Oder BO
> > > > > > > and find a suitable method, you can do it before SO Update
> create
> > a
> > > > > > > pre-prosessiong directive as shown
> NO-ERROR.
> > > > > > > END.
> > > > > > > END
> > > > > > > That should do. it
> > > > > > > *Jose C Gomez*
> > > > > > > *Software Engineer*
> > > > > > > E: jose@...
> > > > > > > On Wed, Jun 29, 2011 at 8:34 AM, Chris Thompson <
> > > > > chriselectrix@...
> > > > > > > >wrote:
> > > > > > > > How do I create a BPM to do what you said?
> > > > > > > > Is it Method Directives? Then what?
> > > > > > > > What Method Code do I select etc?
> > > > > > > > Sent: Wed, 29 June, 2011 13:30:37
> > > > Order/Quote
> > > > > > > Entry
> > > > > > > > screen
> > > > > > > > BPM would be the best option, after GetNewDtl or something
> like
> > > > that
> > > > > > you
> > > > > > > > can
> > > > > > > > copy the Part.Character01 to OrderDtl.Character01 and that
> > would
> > > do
> > > > > it.
> > > > > > > > Another alternative would be a customization on SoEntry where
> > you
> > > > do
> > > > > a
> > > > > > > > lookup on part BO and then grab the value for display. With
> > this
> > > > > > approach
> > > > > > > > however you would need to modify the RDD for SOEntry to
> Include
> > a
> > > > > Link
> > > > > > to
> > > > > > > > the Part Table.
> > > > > > > > *Jose C Gomez*
> > > > > > > > *Software Engineer*
> > > > > > > > E: jose@...
> > > > > > > > On Wed, Jun 29, 2011 at 7:51 AM, Chris Thompson <
> > > > > > chriselectrix@...
> > > > > > > > >wrote:
> > > > > > > > > Hi All
> > > > > > > > > I am starting to use Part.Checkbox01.
> > > > > > > > > How am I able to pull all of the information through from
> > > > > > > Part.Checkbox01
> > > > > > > > > to the
> > > > > > > > > Order Detail and Quote Detail screens and ultimately send
> > them
> > > in
> > > > > the
> > > > > > > XML
> > > > > > > > > on the
> > > > > > > > > quote and sales order ack print out so they can be reported
> > on?
> > > > > > > > > Thanks.
> > > > > > > > > [Non-text portions of this message have been removed]
> > > > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> > You
> > > > > must
> > > > > > > have
> > > > > > > > already linked your email address to a yahoo id to enable
> > access.
> > > > > > > > (1) To access the Files Section of our Yahoo!Group for Report
> > > > Builder
> > > > > > and
> > > > > > > > Crystal Reports and other 'goodies', please goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > > > > (2) To search through old msg's goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > > > > (3) To view links to Vendors that provide Vantage services
> > goto:
> > > > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups
> Links
> You
> > > > must
> > > > > > have
> access.
> > > Builder
> > > > > and
> goto:
> > > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> > > must
> > > > > have
> > > > > > already linked your email address to a yahoo id to enable access.
> > Builder
> > > > and
> > > > > > (3) To view links to Vendors that provide Vantage services goto:
> > must
> > > > have
> > > > > already linked your email address to a yahoo id to enable access. )
> Builder
> > > and
> must
> > > have
> > > > (1) To access the Files Section of our Yahoo!Group for Report Builder
> > and
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have
> and
> have
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
