do we have a way to change form label with any customization like back end db table stores schema in Ice.ZDataField.
A simple screen customization will do
-Jose
I use the following custo for all my modified forms. Under the load event of the form. Showing the customisation name and environment, s often I open different environments at the same time.
EpiBaseForm form = sender as EpiBaseForm;
var tes = (Ice.Core.Session)oTrans.Session;
string EnvFull = test.AppServer.ToUpper();
int index = EnvFull.IndexOf("TRAINING");
Environ = "";
if(index != -1)
Environ = "TRAINING";
else
index = EnvFull.IndexOf("TEST");
if(index != -1)
Environ = "TEST";
//else it is the production env....no need to show...
if(form != null)
form.Text += " - " + form.CustomizationName + ( Environ == "" ? "" : " (" + Environ + ")");
Pierre
thanks @josecgomez for quick reply. I know this way but I have requirement around 10 screen label to be updated so looking the way without customization if not then customization final way to do but will take more time.
You could try the Language Settingsā¦
I am working on this option will update you results thank you
