I am using:
adapterPart.GetByID(row["MtlPartNum"].ToString());
but when I run a sql query it returns 4 records for each company the part is in. How can I get the specified one? Should I make a baq or can I make this work another way?
I am using:
Check your row index. Is this in a loop? Need to see where “row” is defined
It grabs that correctly. It is in a loop.
Depending on how you are returning your adapterPart, you might consider a SearchOptions to define what company it’s using
UserCodesAdapter adapterUserCodes = new UserCodesAdapter(oTrans);
adapterUserCodes.BOConnect();
SearchOptions opts = new SearchOptions(SearchMode.AutoSearch);
opts.PreLoadSearchFilter = "Company = 'YourID'";
opts.DataSetMode=DataSetMode.RowsDataSet;
adapterUserCodes.InvokeSearch(opts);
maybe?
