Probably not, unless you need to write some complex Query that goes through your GL Books and use CURSOR and Variables to get a fancy Total.
I would only use it for those “repeatable things I do”… I think I have this LOGIC Here atleast 18 times repeated throughout BAQs to get a single column, sometimes even Sub-Select Query:
Even for ParCost going to the Plant figuring out my default Part Cost ID over and over again
