Good call. It is not null, though. I am running this through the configurator… Could that be a thing? Maybe I should do this another way. I read about a way to “unbreak” a configurator that was stuck by creating a second configurator and executing the code through it.
So I applied that concept to my current situation. I won’t be offended if you tell me I’m an idiot.
Great points. I didn’t have it [0] originally… I was troubleshooting and I never went back and fixed that. I will take care of it. Thanks! But yeah I can confirm I am retrieving the row in GetByID.
Not sure about that, but perhaps add a message to the catch with the error (or simply throw the exception) so you can see if there is something Epicor is trying to tell you (like maybe update failed because Row has been modified by another user)
I always do throw in the RowMod == “A”
var newUD03Row = (from x in UD03DataSet.UD03 where x.RowMod == "A" select x).FirstOrDefault();
So I decided to throw my Ex, as you suggested. This is what it revealed to me. … what?
Application Error
Error Detail
Message: The underlying provider failed on EnlistTransaction.
Inner Exception Message: The partner transaction manager has disabled its support for remote/network transactions. (Exception from HRESULT: 0x8004D025)
Program: Epicor.ServiceModel.dll
Method: ShouldRethrowNonRetryableException
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets) at Erp.Proxy.BO.ConfigurationRuntimeImpl.ExecutePageOnLoadEvents(String pageLoadEvent, String configID, Guid testID, PcValueDataSet pcValueDS) at Erp.Lib.Configurator.Runtime.ConfigurationServerFunctionsLib.ExecutePageOnLoadEvents(String pageLoadEvent, PcValueDataSet& pcValueDS) at Erp.UI.Cfg.TEST2ad00843c9e04ab7a99209faa390f91d._UNBREAKERPageEventCollection.Page1Load(PageLoadArgs LoadArgs) in c:\Users\dramirez\AppData\Local\Temp\ConfigDump\Client\_UNBREAKERPageEventCollection.cs:line 67 at Erp.Shared.Lib.Configurator.MethodCollection
1.Invoke(String methodName, TMethodArgs args)
at Erp.Lib.Configurator.Runtime.ConfigurationController1.TriggerPageEvent(Int32 callerPageSeq, PageChangeArgs args) at Erp.Lib.Configurator.Runtime.ConfigurationController
1.PageLoad(PageLoadArgs loadArgs)
at Erp.Lib.Configurator.Runtime.ConfigurationController`1.GetNextPage(Boolean skipping, Int32& proposedPageSeq)
Inner Exception
Inner Exception
