What is the best way to get fields on the rcvdtl table populated when the user completes a poreceipt inspection.
Check out this post to see if it helps.
Thanks for the reply. My goal is to write to a couple UD fields on rcvdtl from Inspection Processing once they save a PO inspection. I have tried to use the wizards that are supplied to get information from the porView but it will not write to the DB from the customization no matter what I try. The porView has my UD fields from rcvdtl that I can write to based on the UI fields but after saving the inspection it writes nothing.
