Get Query Execution Parameters By ID no longer working, but not erroring either
	private void EmpGridCheck()
		DateTime startDate = Convert.ToDateTime(edvCallContextBpmData.dataView[edvCallContextBpmData.Row]["Date01"].ToString());
		string startDateString = startDate.ToString("MM-dd-yyyy");
		DateTime endDate = Convert.ToDateTime(edvCallContextBpmData.dataView[edvCallContextBpmData.Row]["Date02"].ToString());
		string endDateString = endDate.ToString("MM-dd-yyyy");
		DynamicQueryAdapter dqadptr = new DynamicQueryAdapter(oTrans);
		dqadptr.BOConnect();
		QueryExecutionDataSet qeds2;
try
        qeds2 = dqadptr.GetQueryExecutionParametersByID("tedUntrainedWork3");
catch(Exception ex)
 // exception is not for hide, it is for problem solving
  MessageBox.Show(ex.ToString());
		qeds2.ExecutionParameter[0].ParameterID = "StartDate";
    	qeds2.ExecutionParameter[0].IsEmpty = false;
    	qeds2.ExecutionParameter[0].ParameterValue = startDateString;
		qeds2.ExecutionParameter[1].ParameterID = "EndDate";
    	qeds2.ExecutionParameter[1].IsEmpty = false;
    	qeds2.ExecutionParameter[1].ParameterValue = endDateString;
		qeds2.AcceptChanges();
	    dqadptr.ExecuteByID("tedUntrainedWork3", qeds2);
	    DataTable results = dqadptr.QueryResults.Tables[0];
		if (results != null && results.Rows.Count > 0)
		grdEmployees.DataSource = results;
		grdEmployees.DisplayLayout.Bands[0].Columns["Calculated_Supervisor"].Width = 200;
		grdEmployees.DisplayLayout.Bands[0].Columns["Calculated_Employee"].Width = 200;
		grdEmployees.DisplayLayout.Bands[0].Columns["OpMaster_OpDesc"].Width = 250;
		grdEmployees.DisplayLayout.Bands[0].Columns["UD251_ShortChar01"].Width = 250;
If I split the parameters out of the try catch I get:
Error: CS0165 - line 92 (250) - Use of unassigned local variable ‘qeds2’
If I put the parameters in the catch, they never get assigned as it breaks out before getting to them.
The only other code in here is:
	private void BpmData_AfterFieldChange(object sender, DataColumnChangeEventArgs args)
		// args.Row["FieldName"]
		// args.Column, args.ProposedValue, args.Row
		// Add Event Handler Code
		switch (args.Column.ColumnName)
			case "Date02":
				EmpGridCheck();
				break;
which is working as it runs EmpGridCheck when Date02 is changed (DateO2 is what I am publishing to from the dashboard, and once again, that value will display without error)
You fire EmpGridCheck twice, when you call server for parameters.
You can see it in the stack.
You need to figure out how to avoid it. Easiest way is to add flag bool isRunning = true/false and check at the beginning of the method.
I originally had an inProcess variable, but it was causing issues as well. Put it back in (changed to isRunning), still had issues.
Broke my EmpGridCheck into two functions (am doing the same thing twice with two different grids and queries) Set the isRunning variable on the first one and set it back to false at end of second one. Surrounded both with try catches and now they work.
Putting the working code here in case anywhere stumbles across this in the future and can glean anything from it. Thank you all for your help. Greatly appreciated!
	try{
			case "Date02":
		if (isRunning == false)
				EmpGridCheck();
				EmpGridCheck2();
	isRunning = false;
				break;
	}catch{isRunning = false;}
			isRunning = true;
try
catch(Exception ex)
  //MessageBox.Show(ex.ToString());
	private void EmpGridCheck2()
			QueryExecutionDataSet qeds;
try{
        qeds = dqadptr.GetQueryExecutionParametersByID("tedUntrainedWork4");
		qeds.ExecutionParameter[0].ParameterID = "StartDate";
    	qeds.ExecutionParameter[0].IsEmpty = false;
    	qeds.ExecutionParameter[0].ParameterValue = startDateString;
		qeds.ExecutionParameter[1].ParameterID = "EndDate";
    	qeds.ExecutionParameter[1].IsEmpty = false;
    	qeds.ExecutionParameter[1].ParameterValue = endDateString;
		qeds.AcceptChanges();
	    dqadptr.ExecuteByID("tedUntrainedWork4", qeds);
catch(Exception ex)
		    DataTable results2 = dqadptr.QueryResults.Tables[0];
		if (results2 != null && results2.Rows.Count > 0)
			grdEmp2.DataSource = results2;
			grdEmp2.DisplayLayout.Bands[0].Columns["Calculated_Supervisor"].Width = 200;
			grdEmp2.DisplayLayout.Bands[0].Columns["Calculated_Employee"].Width = 200;
			grdEmp2.DisplayLayout.Bands[0].Columns["UD251_ShortChar01"].Width = 250;
Solution was a combination of the posts above from Olga and Brandon. Marked my code in the post above as the solution as it combines a few posts in here.
