We are looking at getting MRP going and importing Forecasts into the system. Right now I am testing everything but am getting an error with my Forecast Import. The error says:
“The string was not recognized as a valid DateTime. There is an unknown word starting at index 0.Couldn’t store in ForeDate Column. Expected type is DateTime.”
My DateTime format is 9/30/2019 00:00:00
I am sure this is a simple solution or maybe I need to do something differently but I do not see a clear cut answer on any forum or help document. Was hoping someone could give me a quick fix to keep moving on this.
Along with this error, does someone know a complete template for importing in the Forecast?
I was using the Import Forecast selection under the Actions Tab in Forecast Entry. I chose the CSV file that I created and chose import and that’s as far as I’ve gotten.
This could be completely wrong, that is just what I’ve tried from reading all the help files that aren’t very helpful.
The field is DateTime so it must include time. I just got it to work because I deleted the headings. Now I am getting an error that the file type is not right, but everything I see says to use CSV.
Thank you guys for replying. I finally figured it out. I needed to leave the headings out and the columns had to be in perfect order and filled out completely
It could just be the way Excel portrays the date field in the .csv - defaulting to date and time. The values are all at 0:00:00 o’clock.
I may have misspoken when I thought that was the way the data came out of Epicor. I don’t alter the format of the data when building the forecast from the exported file. Since the data has the date and time in the export, I use the same format for importing. However, the time being displayed could be an Excel .csv file handling feature, and not imbedded in the Epicor forecast export.
