Are you saying that Op 20 is FAI?
If the part needs to be inspected after OP 10 is complete and before anything gets run through OP 20 Iām not sure that qualifies as first article to begin with.
yes
FAI should not be a separate operation, it is a part of the operation that is being performed.
