Dear Team,
I got the following error message. I don’t know to fix it. I tried more than one way but not able to fix it.
Kindly, help on this issue how to solve.
Error Message: Exception of type ‘Ice.Lib.Framework.UIException’ was thrown.
The below Code i used.
private void oTrans_adapter_AfterAdapterMethod(object sender, AfterAdapterMethodArgs args)
// ** args.MethodName **
// ** Add Event Handler Code **
// ** Use MessageBox to find adapter method name
// EpiMessageBox.Show(args.MethodName);
//MessageBox.Show(args.MethodName);
switch (args.MethodName)
case "GetByID":
//tmpSrchGet = "Suppid";
//DMRBindSupplier();
//goto GetAvailTranDocTypes;
string txtPartNo = string.Empty;
string txtLotNo = string.Empty;
string tmpSuppID = string.Empty;
string tmpSuppPurPoint = string.Empty;
string tmpSuppName = string.Empty;
EpiDataView edvDMRHead = ((EpiDataView)(this.oTrans.EpiDataViews["DMRHead"]));
if(edvDMRHead.dataView.Table.Rows.Count>0)
System.Data.DataRow edvDMRHeadRow = edvDMRHead.dataView.Table.Rows[0];
Ice.Lib.Framework.EpiTextBox tmpTxtPartNo = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference(“413bd15f-33af-46d3-9f1d-22c9f00cb1ce”);
Ice.Lib.Framework.EpiTextBox tmpTxtLotNo = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference(“72ffbbf5-68d9-4ecd-a4d0-886c46ccf7d2”);
txtPartNo = Convert.ToString(tmpTxtPartNo.Text);
txtLotNo = Convert.ToString(tmpTxtLotNo.Text);
txtPartNo = Convert.ToString(edvDMRHeadRow[“PartNum”]);
txtLotNo = Convert.ToString(edvDMRHeadRow[“LotNum”]);
MessageBox.Show(txtPartNo.ToString());
MessageBox.Show(txtLotNo.ToString());
DynamicQueryAdapter adapterDynamicQueryQuote = new DynamicQueryAdapter(oTrans);
adapterDynamicQueryQuote.BOConnect();
bool results = adapterDynamicQueryQuote.GetDashboardQuery("MSD_QM_DRMProcess_Gaps07");
if(results)
QueryExecutionDataSet ObQEd= new QueryExecutionDataSet();
DataRow drReqNo = ObQEd.Tables["ExecutionParameter"].NewRow();
drReqNo["ParameterID"] = "PartNo";
drReqNo["ParameterValue"] = txtPartNo;
drReqNo["ValueType"] = "character";
drReqNo["IsEmpty"] = false;
drReqNo["RowMod"] = "A";
ObQEd.Tables["ExecutionParameter"].Rows.Add(drReqNo);
DataRow drDocType = ObQEd.Tables["ExecutionParameter"].NewRow();
drDocType["ParameterID"] = "LotNo";
drDocType["ParameterValue"] = txtLotNo;
drDocType["ValueType"] = "character";
drDocType["IsEmpty"] = false;
drDocType["RowMod"] = "A";
ObQEd.Tables["ExecutionParameter"].Rows.Add(drDocType);
adapterDynamicQueryQuote.ExecuteDashboardParameterized(adapterDynamicQueryQuote.RuntimeQuery,ObQEd);
DataTable dtQuotes = new DataTable();
dtQuotes= adapterDynamicQueryQuote.QueryResults.Tables[0];
if(dtQuotes.Rows.Count > 0)
Ice.Lib.Framework.EpiTextBox txtSuppID = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference("2e703b56-64cd-4fef-b84e-a83b7b641da7");
Ice.Lib.Framework.EpiTextBox txtSuppPurPnt = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference("1786ece3-e2de-44b0-8547-78097534fd75");
Ice.Lib.Framework.EpiTextBox txtSuppName = (Ice.Lib.Framework.EpiTextBox)csm.GetNativeControlReference("b6262a77-a28e-4793-9018-f527ad9dd896");
EpiDataView edvBpm = ((EpiDataView)(this.oTrans.EpiDataViews["CallContextBpmData"]));
System.Data.DataRow edvRowCallCon = edvBpm.CurrentDataRow;
if (dtQuotes.Rows[0]["Vendor_VendorID"] != null && dtQuotes.Rows[0]["Vendor_VendorID"].ToString() != "")
if(edvDMRHeadRow!=null)
edvDMRHeadRow.BeginEdit();
for(int i=0;i < dtQuotes.Rows.Count; i++)
//edvDMRHeadRow["VendorNumVendorID"] = Convert.ToString(dtQuotes.Rows[i]["Vendor_VendorID"]);
edvDMRHeadRow["VendorNum"] = Convert.ToString(dtQuotes.Rows[i]["RcvDtl_VendorNum"]);
edvRowCallCon.BeginEdit();
edvRowCallCon["Number01"]= Convert.ToString(edvDMRHeadRow["VendorNum"]);
edvRowCallCon.EndEdit();
edvDMRHeadRow.EndEdit();
else
edvDMRHeadRow["VendorNum"] = Convert.ToString(dtQuotes.Rows[0]["RcvDtl_VendorNum"]);
//txtSuppID.Value = "";
if (dtQuotes.Rows[0]["Vendor_PurPoint"] != null && dtQuotes.Rows[0]["Vendor_PurPoint"].ToString() != "")
edvDMRHeadRow["PurPoint"] = Convert.ToString(dtQuotes.Rows[0]["Vendor_PurPoint"]);
//txtSuppPurPnt.Value = Convert.ToString(dtQuotes.Rows[0]["Vendor_PurPoint"]);
edvRowCallCon["Character01"]= dtQuotes.Rows[0]["Vendor_PurPoint"];
else
//txtSuppPurPnt.Text = "";
if (dtQuotes.Rows[0]["Vendor_Name"] != null && dtQuotes.Rows[0]["Vendor_Name"].ToString() != "")
edvDMRHeadRow["VendorNumName"] = Convert.ToString(dtQuotes.Rows[0]["Vendor_Name"]);
//txtSuppName.Value = Convert.ToString(dtQuotes.Rows[0]["Vendor_Name"]);
edvRowCallCon["Character02"]= dtQuotes.Rows[0]["Vendor_Name"];
else
//txtSuppName.Value = "";
break;
Screen Shot for your reference.
