Establishing a Session in Kinetic 11.2.300
With Kinetic 11.2, the Server code moved from using the .NET Framework to using .NET (aka .NET Core) and with that change, the use of WCF was deprecated. WCF is still supported but you have to specify which Services will use WCF (via a simple SQL Script) and then the AppServer must be restarted.
Search Help for WCF or contact Support for more information.
