Anyone know if it is possible to pass a parameter to a form url such as PO tracker to automatically load a PO number?
Yeah thereās a thread about this somewhere inhereā¦ do some searching but I know its there.
This was the only one I had found prior to creating the post but it doesnāt give any idea what the parameter would be.
Hmm thereās one let me see if I can find it.
Your search skills are poor sir! LoL
This comes across as extremely condescending, even with the smiley emoji. I once searched for days through dozens of links on e10help and many other sites for the solution to my problem. I couldnāt find the answer to my specific version\language, and at my wits end, I finally posted here for help, only to be told by Jose to google harder.
This killed my topic. There was no further discussion. If you didnāt want to answer, you could have remained silent and a new discussion might have ensued that was more encompassing and up to date, and it could have stood as a new place for people in the future searching to find an updated answer. But mostly, it just left a bad taste in my mouth.
Versions change. Languages change. Methods and functions are deprecated, better solutions are found. Not everyone is a Gold Star Dev that can solution the world. Thatās why we come here. To gain knowledge and build solutions, and then in turn, we share and contribute back.
I eventually pieced together the solution to my problem. I found the key to what I needed on stack exchange, as none of the multitude of topics I poured through on e10help quite covered my exact scenario and I kept hitting dead ends. I built my own comprehensive documentation on the topic, but that knowledge wonāt be found here by future searchers (poor skills or not).
If you want this to be a community that flourishes and grows members that contribute back, let other people provide answers to questions if you canāt be bothered with it. Now, I have some email notification preferences to adjust. /soapbox off
EDIT: Jose reached out to me directly, and everything is resolved. I really do appreciate the response, and hope I didnāt come across as overly bitter, itās been pent up for a while, and it came out rather abruptly. Iām really sorry (@tkoch) for taking away from your topic. I asked Jose to modify or delete my response so people searching in the future donāt have to jump over it, and he said, āI donāt want to hide when I screw upā and refused to change anything. Total integrity. I have gained a wealth of information from e10help, and Iām happy to give back where I can. If I can get freed up today, Iāll compile and post what I came up with and we can see if it applies to your situation, Theodore. /last soapbox, I promise
Ah I didnāt read far enough down on the Launching Specific Epicor Module post, thought it was just for desktop shortcuts based on the title. Thanks Jose
Lee I was being funnyā¦ I donāt think @tkoch too offense to thatā¦ I did give him the answer after allā¦ If I ofended you @tkoch I apologize.
The reason your post "diedā was because you didnāt come back and said you had no luck this has indeed been addressed several times before I was trying to point you in the right direction.
Sorry you took it the wrong way, I would have gladly helped you further or others would have too if you had followed up and said I canāt find it. Like @tkoch did, I will try to turn down my sarcasm if thatās what turned you off sorry dude.
I really wasnāt trying to offend you or anyone sorry @LeeB my responses are always meant to be helpful and the one I gave to you clearly wasnāt helpful to you. Iāll work on making sure that when I do say āgo search for itā it is understood that you are welcomed to ask follow up questions if you canāt find the answer.
Haha Iām good, takes a lot to offend me.
By the way, the solution to this is to add ID=[record id] as an extra parameter to the url that calls the form.
Does this work for all forms? or just PO Tracker?.. #Curious
Only tried PO Tracker, let me try some others.
PO Tracker
Order Tracker
Job Tracker
Quote Tracker
Job Entry
Resurrecting this topic to ask: is this possible to do with Kinetics at all?
