Hi,
I have setting up electronic interface for the Deutche Bank Statement.
The output from Bank is a CSV file. I have modified Erp\EI\StatementImportCSV_Template\StatementImportCSV_Template.cs program and it looks now work 90%. The problem is that the “Start Date” and the “End Date” in the header of the file are in the same field! I cannot find good idea, how to parse this field correctly.
Header example:
Transactions Kontokorrentkonto (00);;;Customer number: xxx xxxxxxxx
01/07/2019 - 01/08/2019
Old balance:;;;;123,456.78;EUR
If I separate dates to the different fields and change manually CSV file like this
01/07/2019 - 01/08/2019 -> 01/07/2019;01/08/2019
I can read the dates and everything works well.
In this case I use in the StatementImportCSV_Template.cs file for the data parsing rows:
headerRules.AddRowValue(2, 1, CSVFieldRule.FieldDesignationEnum.StartDate);
headerRules.AddRowValue(2, 2, CSVFieldRule.FieldDesignationEnum.EndDate);
I have trying to use Substring, but no success.
Any ideas, how to resolve this?
