Are there other options available for the “Select a badge to use as your title” field within the user profile besides none/Consultant or is there another process to edit/manage titles?
For example, a consultant could be any combination of being an Epicor Consultant, an Epicor Certified Consultant, and/or an Epicor Authorized Consultant.
If you are an Epicor Certified Partner there are a few other badges we can / will assign to you if you request it. Which would allow you to have different title. Based on the info on your profile I’ve assigned to you certified and authorized badges which you can use for your title.
BTW authorized consultants are certified consultants that are up to date with the relevant delta certification(s) since earning their base level certification.
It’s been a minor difference historically but Epicor has put more focus on it recently.
