Hello all,
I am not sure if this is possible…
I have a dashboard I need to develop, to gather all LaborDtl records with hours reported on jobs, pertaining to a specific user, between two dates.
So I designed my BAQ with 4 info parameters as Dept (JCDept) EmpID, DateFrom and DateTo. Running the BAQ I get my results ok.
Now, in the Dashboard view, I designed a tracker where I am selecting the department via a combo using BO :JCDept, then in the list of employees combo, it would only show the employees assigned to that dept.
Then you would select the dates From and To.
The issue:
How can I pass the tracker parameters to the BAQ when the user selects to refresh the grid?
A “not so nice” way I thought is to let the BAQ params to show up in it’s window and the user just enter his selections… But, it seems I cannot have the combo showing employees, based on the combo of Departments. (both being based on BAQ’s) using “Epimagic”… I would need to customize the form…
Not sure of the effects of customizing that parameter form…
I would prefer user has a first view of the selections to make… and I could pass the “search parameters” to the BAQ, so the parameter from does not show up…if this is possible, what would be the valid way?
I need some guidance here of the best way to resolve this issue…
Pierre
