<div id="ygrps-yiv-281256326ygrp-text"> <p>
// Custom code for IssueMaterialForm
// Created: 7/22/2015 7:33:39 AM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.UI;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using Infragistics.Win.UltraWinGrid;
public class Script
private Erp.UI.Controls.Combos.JobMtlSearchCombo ctrl;
ctrl = (Erp.UI.Controls.Combos.JobMtlSearchCombo)csm.GetNativeControlReference("3c29bb2b-cc78-4cab-80c8-f004923fdbae");
this.ctrl.BeforeDropDown += new System.ComponentModel.CancelEventHandler(this.ctrl_BeforeDropDown);
this.ctrl.InitializeLayout += new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.ctrl_InitializeLayout);
this.ctrl.BeforeDropDown -= new System.ComponentModel.CancelEventHandler(this.ctrl_BeforeDropDown);
this.ctrl.InitializeLayout -= new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.ctrl_InitializeLayout);
// Begin Custom Code Disposal
ctrl = null;
// End Custom Code Disposal
private void IssueMaterialForm_Load(object sender, EventArgs args)
// Add Event Handler Code
private void ctrl_BeforeDropDown(object sender, System.ComponentModel.CancelEventArgs args)
ctrl.DisplayLayout.Bands[0].Columns[0].Width = 20;
ctrl.DisplayLayout.Bands[0].Columns[1].Width = 100;
private void ctrl_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs args)
args.Layout.Override.AllowColSizing = AllowColSizing.Free;
args.Layout.PerformAutoResizeColumns(true, PerformAutoSizeType.AllRowsInBand,true);
Sent: Wednesday, July 22, 2015 2:55 PM
Subject: [Vantage] Re: E10 Adjust Combo dropdown Width
Can you provide an example of how you did this?
Tanner
</div> <div style="color:#fff;height:0;"></div>
Before re-inventing the wheel.....
On the Issue Material screen, the Mtl Seq dropdown has 3 columns.
Mtl Seq, PartNum, Description.
The Mtl Seq Column is too wide, The PartNum column is too narrow. I have tried various combinations of the Native AutoWidth and AutoWidthOption in the property sheet with no effect.
Does anyone have an example of how to auto resize the columns to fit their contents on a Native Erp.UI.Controls.Combos.JobMtlSearchCombo ?
Reinvention complete
Disregard original message
Sent: Wednesday, July 22, 2015 7:29 AM
Subject: [Vantage] E10 Adjust Combo dropdown Width
Tanner
using System;
using System.Data;
using Erp.UI;
public class Script
ctrl = null;
Tanner
