Does updating a configurator break existing configurations?
Hi @Evan_Purdy,
When you update a configurator it updates the PCStatus_ConfigVersion which causes a mismatch with existing Sales Order Lines or PcValueHead_ConfigVersion. You can update the Configurator Versions by running the Sales Management - Configurator Management - General Operations -
Verify Existing Configurations process:
We actually use the following BAQ to find all of the Orders that are out of Sync:
PcValueHead - PcStatus
-Company = Company
-ConfigVersion <> ConfigVersion
-ConfigID = ConfigID
PcValueHead - PcValueGrp
-Company = Company
-GroupSeq = GroupSeq
PcValueGrp - OrderDtl
-Company = Company
-RelatedToSysRowID = SysRowID
OrderDtl.OpenLine = True
Then based on the BAQ results we run the VEC process, using the Filter tab, for just those Configurator Parts that are out of sync. I hope that helps somehow. :slight_smile:
BTW, VEC Log files can be found in the EpicorData\Companies\WDI\Processes\UserName folder. It’s good to look through these because we’ve seen some errors and warnings in these logs that have helped us fix issues with our Configurators.
