In this example I am indeed passing the parameters as query parameters. If your API consumes from the body of the call, you could wrap up the parameters and add them to the body. I have an example (not Epicor but using C#) below adding parameters to the body of an API call using the RestSharp library.
/// <summary>
/// Invokes an Epicor Function from the specific function library
/// </summary>
/// <param name="library">The Library ID associated with the function</param>
/// <param name="functionID">The Function ID to be invoked</param>
/// <param name="fxRequest">The JSON from the call body representing the optional input parameters</param>
/// <returns></returns>
public async Task<IActionResult> InvokeFunction(string library, string functionID, dynamic fxRequest)
if (_epiUtils.ValidSession(_epiUtils.sessionID, _licenseType, _path, _user, _apiKey, out string msg))
var restClient = new RestClient(_fxPath)
RemoteCertificateValidationCallback = (sender, certificate, chain, sslPolicyErrors) => true
var request = new RestRequest($"{library}/{functionID}", Method.POST);
//add any optional request parameters
request.AddParameter("application/json", fxRequest, ParameterType.RequestBody);
//Web Service License
var headerLicense = new
ClaimedLicense = _licenseType,
SessionID = _epiUtils.sessionID
var header = JsonConvert.SerializeObject(headerLicense);
request.AddHeader("License", header);
request.AddHeader("Authorization", $"Basic {EpiUtils.Base64Encode(_user)}");
request.AddHeader("x-api-key", _apiKey);
IRestResponse response = await restClient.ExecuteAsync(request);
switch (response.StatusCode)
case System.Net.HttpStatusCode.BadRequest:
dynamic content = JsonConvert.DeserializeObject(response.Content);
var value = content;
return BadRequest(content);
case System.Net.HttpStatusCode.OK:
default:
return Ok(content);
else
return Unauthorized(msg);
In my first example, I am using a HttpWebRequest because Epicor doesn’t ship with RestSharp available out of the box in the server assemblies (), so I’m forced to use ancient tech to accomplish that. However, it is possible, just don’t have a great example:
C# JSON Post using HttpWebRequest - Stack Overflow
For your parameters, I don’t believe in doing hard-coded serialization like some people do but an easy way to accomplish that is to add your parameters to a Dictionary and serialize the whole thing into JSON :
//add custom field values to this dictionary
var customFields = new Dictionary<string,string>;
{"Physician","Dr. Test"}
,{"Patient", "Test Patient"}
,{"Graft Requested", "Femoral Core, 10mm"}
,{"Graft Offered", "Femoral Core, 10mm"}
,{"Graft ID", "123456-999"}
,{"Release Date", "10/18/2018"}
,{"Expire Date", "10/30/2018"}
,{"Patient Size Msg", "TW=N/A, W=N/A, L=N/A (bunch of text here)"}
,{"Donor Size Msg", "TW=N/A, W=N/A, L=N/A (bunch of text here)"}
,{"QuoteDtl Comment", "Please see dissection sheet for specific sizing"}
,{"ASC", "Aaron Moreng"}
,{"Offer Date", "10/18/2018"}
Or if you like even less code, you can just use an anonymous type to build your body and serialize it:
var taskHead = new
planId = bucket.PlanID,
bucketId = bucket.BucketID,
title = "New Task from Teams Bridge"
var content = JsonConvert.SerializeObject(taskHead);
Because you won’t have the ability to create a model for your response, I’d also recommend using the dynamic
type when reading your response, especially if you are accessing nested data within it.
RE: Nested json; you’ll be able to do this with ease using anonymous types. That’s definitely what I’d recommend for this.
Anonymous Types | Microsoft Docs
