DMT & Change Log Report - Assistance Needed
Found the issue. Forgot to include the line number and rel number. Once included that error stopped occurring.
ttOrderRel.SetUDField<System.String>("PrevShipTo_c", ttOrderRelRow.ShipToNum);
But im not sure if you can add it in the expression, unless you use ttOrderRelRow.SetUDField
@hkeric.wci,
That seemed to do the trick! Thank you sir!
Next Section of the project is to schedule DMT. I’m currently looking into how to use Windows scheduler to run it, but I haven’t found anything that tells it where to look to files or how to do so. If anyone has so insight on how to I would greatly appreciate it.
I am currently following these two posts:
What I don’t understand is what is to go in the custom c# coding section. Does anyone know what is to be put there?
I use Windows Task Scheduler to run a DMT daily. But the windows task specifies a PowerShell(PS) script to run at a certain time each day.
You could make a PS script, that checks for the existence of a file and the if it exists, the call DMT via the command line, and then delete the file. This PS script could be scheduled to run every 5 minutes.
Looking for something like that?
edit
And here’s a lengthy topic on DMT and PowerShell
and FWIW - I struggled with how to use quotes in a string that is referenced by another string.
