Default Search Page Size Setting
Version: 10.1.600.16
Other then updating the .mfgsys config files 'DefaultSearchPageSize value=“100” parameter is there a way to do this system wide? Or perhaps a setting in Epicor itself to change this? Seems kind of cumbersome to have to go around and update the individual clients config files for this.
-Thanks
If you update the .sysconfig file on the server deployment folder, then the clients should detect a change and pull down the update. There are many posts before describing this, look for one by @aidacra
If you open a Support case on this, I will submit it to development as an enhancement request to move everything out of the sysconfig to the user record that is possible.
my one concern with this request is the hit performance may take if everyone’s searches are returning 1000 rows. anyone have any input on that aspect of it?
