Yep this is one for me. This is currently not on the list for 400 and I will need to review level of effort as 400 is already past full and we would need to re-prioritize if this is more than a few hours of work.
I will be asking the BAQ team to see how much work it would be to allow the use of BAQData field values in Constraints / Filters. That would require a little code work from you but you should be able to reduce / remove the necessity to have the parameter prompting and that work would provide value into the Kinetic future…
