Rick, yes I was afraid that was the answer. I suspect a solution will require a BPM or Form-Side Code to enact. thanks for the reply!
-Keith
-Keith
--- In vantage@yahoogroups.com, "that_guyy" <rbird@...> wrote:
> Keith,
> If you enable the Ship Doc Required on the Part or on a Job (for make direct), the pack slip cannot be marked shipped until an attachment is made to the Pack slip of a Doc Type that has 'Shipment' enabled.
> We use this for Quality documents that the Customer requires... a COA for example.
> Auto print the instructions on shipment? You might be able to do it with .NET code in a BPM, but not with this functionality. What I would try to do, is attach the instructions to the part in Part Maint. and then have a BPM on the Pack for it's closed or marked shipped to look up the file path and with .NET execute a print command? No idea how to do this, but that would be my first swing at it.
> Does that help?
> -Rick Bird
> IT Software Administrator
> Rowmark, LLC.
> 9.05.700B2
> --- In vantage@yahoogroups.com, Keith Walter <keithfwalter@> wrote:
> > Can anyone explain the Required For Shipment functionality in Vantage 8.03.409c? As in Doc-Type-Maintenance and Part-Maintenance?
> > Â
> > We need a slick method of having user-instructions print at time of shipment for certain items. Can this functionality help?Â
> > Â
> > Thanks,
> > Keith
