Keith,
Attached you will find an .PDF that shows the current output .CSV file that
we run from the UPS worldship software program, which contains the info we
would like to pull into Vantage. The First column is the Packing Slip
number, The Second column is the Order Number, The third column is the
individual package cost, the fourth column is the UPS tracking number, the
fifth column is the total shipment weight, the sixth column is the total
shipment cost, the seventh column is the total number of packages in the
shipment. It looks like we can get ride of the third column altogether. As
you can see it currently repeats the ship lines with multiple boxes so that
will be a problem.
In the whole it would be nice to populate the Misc. Charges on the packing
slip portion of Vantage with the Sixth column of data. Populate the number
of packages and the shipping weight fields with the fifth and seventh
columns respectively. Populate say the memo field with the tracking number.
Also other things we would like to see is possible on the order user fields
a checkmark to specify if the order or packing slips are to be charged
shipping cost or not, this might be accomplished with a routine which leaves
out specific shipping codes such as our collect code.
Please give me a call with any questions or comments. I look forward to
hearing from you on this programming.
Eric Tolliver
IT\MIS
Continental Industries Inc.
5456 E. Mcdowell Rd.
Mesa, Az 85215
http://ciirelays.com/
mailto:e.tolliver@...
Sent: Tuesday, August 15, 2000 12:47 PM
To: vantage@egroups.com
Subject: RE: [Vantage] Custom Progress Programming
I would be interested in speaking to you about any customization you are
looking for.
Keith E. Taylor
Vice President
LBSi
Business Systems Consultants (Progress based ERP packages)
216/476-1416 ext 26
keith@...
Sent: Tuesday, August 15, 2000 2:52 PM
Subject: [Vantage] Custom Progress Programming
I am looking for someone that can write a progress based program that
I can attach to a VB Form button. I need it to do a weighted average
monthly usage (STK-MTL, STK-UKN, PUR-MTL transaction types)of the
given material to wich the VB Form is attached. Is anyone interested
or does anyone have any recomendations for a good progress programer
who could give a better price that Custom Programming?
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password,
the link above will work the next time you try it.)
will be a problem.
Eric Tolliver
IT\MIS
Mesa, Az 85215
looking for.
Keith E. Taylor
Vice President
LBSi
216/476-1416 ext 26
keith@...
