I have a question on whether it’s better to use the SysRowID to match up the UD table?
Currently I have Key1 as JobNum, Key2 as AsmSeq and Key3 as MtlSeq. I’m running a union query to get all Assemblies and Materials into one list, (Assemblies just have 0 for the MtlSeq). With that set up, I can run the Union query against what I have in the UD table and add or remove as necessary.
Now, after I have all that set up, I’m wondering if it would have been better to use the SysRowID instead? Theoretically, that would work just as well as the other keys (or maybe in conjunction with?). And would that run faster in a query? I still need to pull the Job Asm and Mtl tables to make keep these tables in sync, so I don’t know if there is anything that I can leave off the query, but would using that key make it run faster?
If anyone has any experience with this type of application that would lend any input, that would be greatly appreciated.
