I leveraged the native EpiDataView “ReportParam” inside Mass Print AR Invoices to submit each invoice number in the list to the task agent quickly. The only problem I’ve had with this approach is that if they are submitted too quickly, there has been instances where the report header does not match the report details, resulting in some really wonky invoices. To solve, I put added Thread.Sleep(500)
inside my foreach
loop and that has served me well.
/// Custom code for ARInvForm
// Created: 5/20/2016 3:08:40 PM
using System;
using System.ComponentModel;
using System.Data;
using System.Diagnostics;
using System.Windows.Forms;
using Erp.UI;
using Ice.Lib.Customization;
using Ice.Lib.ExtendedProps;
using Ice.Lib.Framework;
using Ice.Lib.Searches;
using Ice.UI.FormFunctions;
using System.Text.RegularExpressions;
using System.Threading;
public class Script
private EpiDataView edvReportParam;
DataTable dtInput = new DataTable();
string Invoice;
bool printed = false;
this.edvReportParam = ((EpiDataView)(this.oTrans.EpiDataViews["ReportParam"]));
this.edvReportParam.EpiViewNotification += new EpiViewNotification(this.edvReportParam_EpiViewNotification);
this.btnAdd.Click += new System.EventHandler(this.btnAdd_Click);
this.btnRemove.Click += new System.EventHandler(this.btnRemove_Click);
this.btnPrint.Click += new System.EventHandler(this.btnPrint_Click);
this.txtAddInvoice.Validated += new System.EventHandler(this.txtAddInvoice_Validated);
this.btnClear.Click += new System.EventHandler(this.btnClear_Click);
dtInput.Columns.Add("Invoice",typeof(int));
dtInput.Columns.Add("Printed", typeof(bool));
this.edvReportParam.EpiViewNotification -= new EpiViewNotification(this.edvReportParam_EpiViewNotification);
this.edvReportParam = null;
this.btnAdd.Click -= new System.EventHandler(this.btnAdd_Click);
this.btnRemove.Click -= new System.EventHandler(this.btnRemove_Click);
this.btnPrint.Click -= new System.EventHandler(this.btnPrint_Click);
this.txtAddInvoice.Validated -= new System.EventHandler(this.txtAddInvoice_Validated);
this.btnClear.Click -= new System.EventHandler(this.btnClear_Click);
// Begin Custom Code Disposal
// End Custom Code Disposal
private void edvReportParam_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
// view.dataView[args.Row]["FieldName"]
// args.Row, args.Column, args.Sender, args.NotifyType
// NotifyType.Initialize, NotifyType.AddRow, NotifyType.DeleteRow, NotifyType.InitLastView, NotifyType.InitAndResetTreeNodes
if ((args.NotifyType == EpiTransaction.NotifyType.Initialize))
if ((args.Row > -1))
//MessageBox.Show(edvReportParam.dataView[edvReportParam.Row]["InvoiceNum"].ToString());
private void ARInvForm_Load(object sender, EventArgs args)
// Add Event Handler Code
EpiDataView dvRP = (EpiDataView)oTrans.EpiDataViews["ReportParam"];
//MessageBox.Show(dvRP.dataView[dvRP.Row]["InvoiceNum"].ToString());
dtInput.Clear();
grdInput.DataSource = dtInput;
//EpiDataView dvRP = (EpiDataView)oTrans.EpiDataViews["ReportParam"];
Invoice = dvRP.dataView[dvRP.Row]["InvoiceNum"].ToString();
if (Invoice != "0")
dtInput.Rows.Add(Invoice, printed);
private void ReadOnlyDT()
foreach (DataColumn dc in dtInput.Columns)
//dc.ReadOnly = true;
private void btnAdd_Click(object sender, System.EventArgs args)
//Invoice = txtAddInvoice.Value.ToString();
if (String.IsNullOrEmpty(txtAddInvoice.Text)) return;
//regex
Regex regex = new Regex(@"^[0-9]{6}$");
Match match = regex.Match(Invoice);
if (match.Success)
else
MessageBox.Show("Enter a 6 digit invoice number");
txtAddInvoice.Clear();
txtAddInvoice.Focus();
private void btnRemove_Click(object sender, System.EventArgs args)
for(int i = dtInput.Rows.Count-1;i>=0;i--)//backwards loop
DataRow dr = dtInput.Rows[i];
if (dr["Invoice"].ToString() == Invoice)
dr.Delete();//will remove any duplicate entries, so be careful
grdInput.Refresh();
private void btnPrint_Click(object sender, System.EventArgs args)
txtNumberInvoicesSent.Value = 0;
if (dtInput.Rows.Count<1){ MessageBox.Show("No Invoices Selected for Print");
return;}
string workID = oTrans.WorkStationID.ToString();
try {
foreach (DataRow dr in dtInput.Rows)
dvRP.dataView[dvRP.Row]["InvoiceNum"] = dr["Invoice"];
dvRP.dataView[dvRP.Row]["AutoAction"] = "SSRSPREVIEW";
dvRP.dataView[dvRP.Row]["WorkstationID"] = workID;
dr["Printed"] = true;
oTrans.Update();
oTrans.SubmitToAgent("SystemTaskAgent", 0, 0);
Thread.Sleep(500);
txtNumberInvoicesSent.Value = dtInput.Rows.Count;
oTrans.PushDisposableStatusText("Reports Submitted for Preview...", true);
catch (Exception ex)
MessageBox.Show(ex.Message);
private void txtAddInvoice_Validated(object sender, System.EventArgs args)
private void btnClear_Click(object sender, System.EventArgs args)
dtInput.Clear();
txtNumberInvoicesSent.Clear();
Rpt.ARInvForm.ARInvForm_Customization_MassPrintSelectInvoice_CustomExport.xml (40.8 KB)
