Close the Quote Entry screen on after adapter method
Hello All,
We are trying to Close the Quote Entry screen on after the adapter method in Quote Form and we get the following error.
So basically when we click create sales order on quote form we pass the order num and open order entry screen.
Everything works even it closes the quote form but we get the below error …can someone help (we already tried oTrans.NotifyAll() before quoteform close)
Application Error
Exception caught in: Erp.UI.QuoteEntry
Error Detail
Message: Object reference not set to an instance of an object.
Program: Erp.UI.QuoteEntry.dll
Method: checkQuoteHedClosed
Client Stack Trace
at Erp.UI.App.QuoteEntry.Transaction.checkQuoteHedClosed()
at Erp.UI.App.QuoteEntry.Transaction.resetActionMenus()
at Erp.UI.App.QuoteEntry.Transaction.GetQuoteData(Int32 quoteNum)
Application Error
Exception caught in: Erp.Adapters.QuoteAsm
Error Detail
Program: Erp.Adapters.QuoteAsm.dll
Method: get_quoteAsmData
Client Stack Trace
at Erp.Adapters.QuoteAsmAdapter.get_quoteAsmData()
at Erp.UI.App.QuoteEntry.Transaction.jobUndo()
at Erp.UI.App.QuoteEntry.Transaction.Undo()
at Erp.UI.App.QuoteEntry.CreateOrderWizardForm.OnClosing(CancelEventArgs e)
The code is here
private void oTrans_adapter_AfterAdapterMethod(object sender, AfterAdapterMethodArgs args)
                          // ** args.MethodName **
                          // ** Add Event Handler Code **
                          // ** Use MessageBox to find adapter method name
                          // EpiMessageBox.Show(args.MethodName)
                          switch (args.MethodName)
                                         case "GetByID":
                                                        EpiDataView edvQuoteHed = ((EpiDataView)(this.oTrans.EpiDataViews["QuoteHed"]));
                                                        if ((bool) edvQuoteHed.dataView[0]["Quoted"] == true)
        btnPDF.Enabled = true;
                                                        else
        btnPDF.Enabled = false;
        //code to check on after get by id if sales order was created from quote.
        //MessageBox.Show("In Get BY ID After method with var set to: " + createdSalesOrderFromQuote.ToString());
        if (createdSalesOrderFromQuote)
        createdSalesOrderFromQuote = false;
        try
        string passedOrderNum = (string)edvQuoteHed.dataView[edvQuoteHed.Row]["ShortChar05"];
        MessageBox.Show("Call Context Character10: " + passedOrderNum);
        if (!String.IsNullOrEmpty(passedOrderNum))
        ProcessCaller.LaunchForm(oTrans, "OMMT3001", passedOrderNum);
        QuoteForm.Close();
        catch (Exception e)
        MessageBox.Show(e.Message,"Error launching order entry form.");
                                                        break;
We are getting this issue as well, did you get a solution?
