Can't add more items to Kinetic Application Maintenance
Just curious, why is that?
NVM: Disabling kinetic from menu maintenance - ERP 10 - Epicor User Help Forum (epiusers.help)
Epicor SHOULD be helping you with that small print font problem. The best solution is to get that solved. If you have a ticket number, raise that with the Kinetic team or post it here so maybe @Edge can follow up on it for you.
