Currently working on a BPM to warn the user if there is no Standard cost on the Part entered on an Inventory Purchase Order. I have the logic to send a warning if there is no inventory cost on a purchase order, but when I try adding in the Inventory tran type PUR-STK it doesn’t work as I would like. Is there another way to do this logic?
I wonder if the row is “changed” when you check?
Sounds like you can get a message if you leave out the condition line for the PORel?
If so, I sometimes include the related RowMod(s) in my messages… they are not always what I think they should be.
You should use the GetNewPart method, and then check if that part has a Std Cost and if it is Qty Bearing (as Qty Bearing parts are the only ones that can go into stock). See the following thread that had a similar issue of wanting to check for a Std Cost before allowing the part to be added…
That thread only checks the StdCost (and see later post about adding CostID for extra data integrity). You could do a similar thing to check the parts QtyBearing status. Or check the PO line type (Buy to stock, job, or other)
If you are multi-site, this could be complicated by the fact that different sites can have different Qty Bearing and CostID’s.
