This and many other topics like it are covered in-dept with examples in the Ice Customization and Experience guides available in Epic Web.
https://epicweb.epicor.com/doc/Docs/EpicorCustomization_UserGuide_102200.pdf
https://epicweb.epicor.com/doc/Docs/EpicorICETools_UserGuide_102200.pdf
https://epicweb.epicor.com/doc/Docs/Epicor10_ConvertedCode_ProgrammingGuide_102200.pdf
I suggest some thorough study of these and come back to us if you still have questions after
tse.dba
(Andrew Koemm)
June 13, 2018, 8:37pm
3
The documents you sent me have good information. However, I cannot find anything to helps me accomplish my goal.
Displaying a MessageBox on a BPM is definitely covered in those documents.
tse.dba
(Andrew Koemm)
June 13, 2018, 8:40pm
5
Displaying a message box i knew how to do before I created this post. I need it to query data about a customer in an order. If the queried data matches a condition, then i have the message box pop up. Does this make sense.
Banderson
(Brandon Anderson)
June 13, 2018, 9:04pm
6
there is a criteria in the conditions for making a query, and if the row exists, do something.
The Help Files are also available and accessible online.
Not everyone knows that the Help for Epicor ERP products are available on line. That can be very handy if your local installation is not available. These days it includes much more than the description of each screen in the application, you’ll...
Reading time: 1 mins 🕑
Likes: 9 ❤
Hope that helps
rbucek
(Rob Bucek)
June 13, 2018, 9:56pm
8
Use a condition element, choose the number of rows in the designed query is not less than one. Use the baq editor to create a query to verify the country of origin is outside the US. The help documents mentioned by previous and subsequent posters covers creating BAQ’s.
tse.dba
(Andrew Koemm)
June 15, 2018, 3:57pm
9
Is there any way to preview a query in the workflow designer?
tse.dba
(Andrew Koemm)
June 15, 2018, 4:00pm
11
Dang, thats going to make it tough
tse.dba
(Andrew Koemm)
June 15, 2018, 4:09pm
12
So here is my workflow:
This is my conditional query and criteria:
My message pops up for any Supplier I choose:
What could I be doing wrong? I figure its the query, but I cannot preview the query to see what exactly its showing.
josecgomez
(Jose C Gomez)
June 15, 2018, 4:11pm
15
ok what does your relationship between Vendor and ttPO look like? Click on the Line
josecgomez
(Jose C Gomez)
June 15, 2018, 4:13pm
17
What method is this running on?
Banderson
(Brandon Anderson)
June 15, 2018, 4:14pm
18
Have you put the results for the TT table into your message box? I’d be curious to see what lines are being returned.
tse.dba
(Andrew Koemm)
June 15, 2018, 4:18pm
20
Erp.PO.Update
Pre-Processing
You want that message to pop up everytime record is saved? If not, your going to need criteria for added rows.
josecgomez
(Jose C Gomez)
June 15, 2018, 4:19pm
22
Remove the Criteria from the ttPOHeader table on the BAQ.
