BPM/Function Error
Mostly because I am still better at the ubaq than the Function! LOL! And, I get the fields to update with zero issues.
Then yes, yes you can
On the Setup Method Parameters in Functions, it has things like CheckForOrderChanged. I do not see these as Table columns, so do I just put in a variable for them? Not sure how these in and out parameters work in this case.
In functions, once you have them setup, do you need to put them in a bpm to fire? Or will they fire regardless?
