Bartender - Print to different printers using the same label?
IF you use Bartneder Commander you can generate a file with the Printer (and other information on it) then Bartender COmmander will process that file and Print to the submited printer.
 %BTW% /AF="MyLabel.bt" /D="%Trigger File Name%" /PRN="MyPrinterHere" /R=3 /P /C=1 /DD
