Building some BAQ reports to use with bartender. I have everything built correct as I have other bartender reports using standard data definitions, and have BAQ reports running for SSRS reports working with no problem.
There must be something I am missing for the two to work together. I have the BAQ report built, a style pointing to the correct .bt file and a output location which is the same as my other bartender reports. When I run the report to get the text output file for Bartender, I get no file in that directory but the task agent says the report was complete.
Any ideas on what I am missing?
