I added a Y/N type Option Field in an existing BAQ Report called “Hide if complete” which hides customer order lines if: completed quantity = required quantity.
By default it is ticked as Y, which means the report only shows order lines which are not complete and/or partially complete.
If the user unticks this option, the report shows only the lines where completed quantity = required quantity.
So to summarise, I created the calculated field as a BIT type, which means I only have two options. Therefore, the report user can either see (1) completed orders, or (2) uncompleted orders.
Instead, I would like the user to be able to see (1) completed orders, or (2) ALL orders together. Is there any way to do this?
What I do, is to make a Calculated field, of typ nvarchar, that returns “YB” if the boolean field is true, and “NB” if it is false.
Then in Reports and Dashboards, you can filter on that field, with a filter type CONTAINS. Then the user can Enter a ‘Y’ to get records where the boolean field is true, ‘N’ for records where it is false, and ‘B’ for both.
Technically you don’t even need to Enter ‘B’, as leaving it blank also returns all records.
