I tried the parameter, it works when I am in Crystal Reports developer.
When I run it from the Epicor menu, I am not prompted by the parameter in print preview.
Is there something I am missing?
I used to be able to prompt when I was using SQL and the datasource was different from the ADO.net we are using with Progress.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Winter, Patrick
Sent: Monday, November 04, 2013 2:35 PM
Subject: RE: [Vantage] BAQ Report Designer
The only way I was able to do this was to filer on the crystal side, if you haven’t done it there it’s a parameter field linked to record filter which then prompts you when you print or preview the report.
I get java errors printing directly but print preview then printing works.
Patrick Winter
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of cathy@...
Sent: Monday, November 04, 2013 14:49
Subject: [Vantage] BAQ Report Designer
I created a BAQ so that we can have a Sales Return Rate.
I used the parttran for transtype - MFG-CUS, STK-CUS and RMA-INS (RMA receipts).
The MFG and STK to CUS had the customer number on the record.
The RMA-INS did not.
I created a calculated field based on TransType and called it CustomerID.
When I created a report through BAQ report designer, it does not let me use the calculated field as filter.
Is there a way around this? Is there a way I can use my calculated field as a filter.
We are on Epicor 9.05.605 and have a progress DB
