Did the updateable dashboard get shared? I would love to see that!
---In vantage@yahoogroups.com, <msantillan@...> wrote:Did this ever get uploaded? Cant seem to find it.
--- In vantage@yahoogroups.com, Anthony Gercar <agercar@...> wrote:
> Ill post it soon. It helps my closing process because I specify the completion and closing dates.
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Deirdre Sykes
> Sent: Tuesday, April 2, 2013 11:44 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: Auto Job Complete/Close Process
> Please forward a copy of the dashboard, if possible the parameters used to set it up. This is something interesting that we can use to help our close process.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Greg Payne
> Sent: Tuesday, April 02, 2013 10:42 AM
> Can you post it to the file section, so we can download? We don't do 200 a day, but it is still a process.
> Thanks
> Greg Payne
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Miguel Santillan
> Sent: Tuesday, April 02, 2013 11:30 AM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Anthony,
> Can I see that updatable? We close about 200 jobs / day. The time it takes is crazy. We do have the Auto Process running, so far it is working fine after a lot of tinkering with the parameters in test.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Anthony Gercar
> Sent: Tuesday, April 02, 2013 6:36 AM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> I have an updateable dashboard I can send you. I copy it to excel, change the complete and close to true, enter dates for closing/completion, then paste insert. It works great! I can close 100 jobs in less than 2 minutes.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of brad_boes
> Sent: Tuesday, April 2, 2013 9:31 AM
> To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> Subject: [Vantage] Re: Auto Job Complete/Close Process
> What version are you on?
> We moved from 9.05.603 to 9.05.700C recently. We had job completion automated in 603, but could not automate the job closing because of the "not yet shipped from WIP" consideration. This is corrected in the 700C version and we have the job closing automated now also.
> If you set it up on a test system and then look at the exception trackers you will see what kicks out. The items you mention should get set aside to show on the exception dashboard.
> Brad Boes
> Metalworks
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, "Cathy" <cathy@<mailto:cathy@<mailto:cathy@%3cmailto:cathy@<mailto:cathy@%3cmailto:cathy@%3cmailto:cathy@%3cmailto:cathy@<mailto:cathy@%3cmailto:cathy@%3cmailto:cathy@%3cmailto:cathy@%3cmailto:cathy@%3cmailto:cathy@%3cmailto:cathy@%3cmailto:cathy@>>>>> wrote:
> > If it MFG-CUS, it will become a candidate when the last operation is complete. It does not have to be shipped.
> > Same with MFG-STK. It does not have to be received into stock.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Joshua Giese
> > Sent: Monday, April 01, 2013 1:37 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > Subject: Re: [Vantage] Auto Job Complete/Close Process
> > If it is make direct (MFG-CUS) then it does not become a candidate until it is shipped. Is that the case or is this MFG-STK?
> > Joshua Giese
> > CTO
> > 920.437.6400 Ext. 337
> > Site ID: 27450-E905700B2-SQL64
> > ----- Original Message -----
> > From: "Stan Chmura" <schmura@ <mailto:schmura%40fiberoptix.com<mailto:schmura@%20%3cmailto:schmura%40fiberoptix.com<mailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com<mailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com<mailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com%3cmailto:schmura@%20%3cmailto:schmura%40fiberoptix.com>>>>> >
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > Sent: Monday, April 1, 2013 3:31:07 PM
> > Subject: RE: [Vantage] Auto Job Complete/Close Process
> > In my test I found a job that was a candidate because the completed qty on
> > final op was marked as complete, but the shipping was incomplete.
> > This communication is intended only for use by the addressee(s) named herein
> > and may contain technical data as defined in the International Traffic In
> > Arms Regulations (ITAR) 22 CFR 120.10. or the Export Administration
> > Regulations. Export of this material is restricted cannot be exported to
> > foreign persons or foreign destination without prior written approval from
> > the U. S. Department of State or the US Department of Commerce.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On Behalf Of
> > Joshua Serwe
> > Sent: Monday, April 01, 2013 3:13 PM
> > Jobs are not candidates for auto complete/close if they are still in WIP
> > so you shouldn't have to worry about that.
> > Josh Serwe
> > Wisconsin Converting Inc.
> > Warehouse & Logistics Manager
> > (920)437-6400 x 330
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> > Behalf
> > Of stanchmura
> > Sent: Monday, April 01, 2013 1:50 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Auto Job Complete/Close Process
> > Hi:
> > Looking for someone who has tried or better yet, is successfully using
> > this function. After just a couple minutes of looking at the set up and
> > trying a quick test run, there are some parameters we consider before
> > completing or closing jobs that are not included in the set up. i.e. is
> > the last operation complete? (necessary to calculate profitability) Is
> > shipping complete? Or better stated, does the Shipped and/or Received
> > quantity match the production quantity? (can't ship/receive from a closed
> > job). As a minimum, seems to me those items should somehow be included in
> > the closing parameters set up.
> > Any one have any luck with this?
> > Thanks
> > Stan
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
> CONFIDENTIALITY: The information contained in this email message, including any attachment(s), may be privileged and confidential and protected from disclosure. The email is not intended for transmission to, or receipt by, any unauthorized persons. If the reader of this message is not the intended recipient, or an employee or agent responsible for delivering this message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication or use of the information contained herein is strictly prohibited. If you have received this electronic mail transmission in error, please delete it from your system without copying or disseminating, and notify the sender by Reply email, so that our address record can be corrected.
