I am attaching documents to receipt entry. The documents are located on a network folder and attach with no problem. However when I go to open the attachment it opens a different folder on the network not the attached document. Any ideas what is happening? Is the system pointed towards a certain folder to look for the documents?
Are you using the Document Management module? If so, where does DocMgmt say it goes?
Charlie Smith
CRS Consulting Services
860-919-1708
Where is the document management module located? If I go to external file reference the location of the document shows correctly.
