One of my other passions is unusually the good ole Vanagon. Just wondering if anyone else had some other thing other than Epicor that you did in your spare time?
Thereās more to life than Epicor?
You might be onto something thereā¦ What about Vanagons?
Didnāt even know what that was until 2 minutes ago when I Googled it.
As Joshua Bardwell saysā¦āYourāre goijng to learn something todayāā¦ And you did Yeah!
Does that mean I can go home now?
You are excused until the 7th of January
Weāre fully circle now. What am I gonna do for two and a half weeks without Epicor??
Wellā¦Thereās this small e10 implementation project going on in Australiaā¦
Sounds like a few courses in Angular, and TypeScript could fill up that voidā¦ #TrustMe youāll need them in the future.
What are you using those for?
Itās what the next Epicor Framework is based on, so learning the language and such before its released will give you a huge advantage. Think learning C# before you get into Epicor.
Makes sense. Is there a release that uses it, so I can play with it in the Epicor world?
C# isnāt going away, is it?
Therāes nothing public that uses it yet, but you can play with it and REST.
Iām just starting to understand C#!!! !!! !! Now I have to learn something new!!! !!! !!
I would expect that there will a choice to select when customizingā¦ like currently it is between VB and C#, a new choice will show as TS maybe ?
Pierre
@Hogardy its a whole new framework and a whole new environment. They demoed some of it at Insights last year, Epicor University is using it now as their interface. All Web Based.
ohhh I seeā¦sorryā¦ so complete different way to use Epicorā¦sounds promising !..
When it will be implemented, would that mean converting our c# to Typescript (similar as going from 9 to version 10) ?
As wellā¦timeframe of availability? we are talking months or years ? (if such info was provided of courseā¦)
tks
Pierre
