Has anyone been able to create a BAQ that returns the same results as the AP Advance Payment Balance Report? I found the field PODetail.AdvancePayBal but the value in this field does not match the Epicor report. I was asked to create a dashboard of this reports results along with additional information but i’m stuck just getting the report to balance to my BAQ.
I was just building a BAQ for this and using the fields in your comment tied out to the report. I am curious, does you company make partial payments in advance?
Did you ever find a solution for this? I wonder if that is what caused it. The canned report doesn’t display the correct Advanced Balance amount with the correct PO line for us so the BAQ I have is much more useful. I am currently trying to figure out why we have one scenario where a closed PO is still on the report and balances to the GL. The $0 invoice that closed it has no tranGLC that would normal reverse it out of the advanced billing account.
select
[Vendor].[VendorID] as [Vendor_VendorID],
[PODetail].[PONUM] as [PODetail_PONUM],
[PODetail].[POLine] as [PODetail_POLine],
[PODetail].[PartNum] as [PODetail_PartNum],
[PODetail].[AdvancePayBal] as [PODetail_AdvancePayBal],
[PODetail].[OrderQty] as [PODetail_OrderQty],
[PODetail].[PUM] as [PODetail_PUM],
[PODetail].[UnitCost] as [PODetail_UnitCost],
[PODetail].[ExtCost] as [PODetail_ExtCost],
(Case
When PODetail.OpenLine = ‘TRUE’ then ‘OPEN’
else ‘CLOSED’
End) as [Calculated_Open],
[APInvDtl].[InvoiceNum] as [APInvDtl_InvoiceNum],
[APInvDtl].[InvoiceLine] as [APInvDtl_InvoiceLine],
[APInvDtl].[ExtCost] as [APInvDtl_ExtCost]
from Erp.PODetail as PODetail
inner join Erp.POHeader as POHeader on
PODetail.Company = POHeader.Company
and PODetail.PONUM = POHeader.PONum
inner join Erp.Vendor as Vendor on
POHeader.Company = Vendor.Company
and POHeader.VendorNum = Vendor.VendorNum
inner join Erp.APInvDtl as APInvDtl on
PODetail.Company = APInvDtl.Company
and PODetail.PONUM = APInvDtl.PONum
and PODetail.POLine = APInvDtl.POLine
where (PODetail.AdvancePayBal <> 0)
