That was for adding a CR BAQ Report, but from step 7 it is the same. Basically run the report with a style that specifies a CR type and has the desired Data Def. That will create an XML file of the report results data. That XML file will be used by CR Designer
Steps 12-21 are the parts that update the Car’s data source. In place of 22, copy the file to your server
