In Part Master Search, I want to add 1 more column in SortBy column. I want to add Description in SortBy. Since its a based search we cant do anything. But how to add in Quick Search this option.
I tried using BAQ for SortOption but there is nothing like parameter which will pass in BAQ for sort by.
I checked in trace log but this method is not being called.
Can you let us know how to add this extra or new column into the default SortBy option of Part.
Thanks.
Yea its Get.Rows calling. This will work when we click on Search Button and based on parameter selected, it will display the result. But my query is before click on Search, I want to put value into SortBy Column of Part. Means when InvokeSearch method is called and search window popup, at that time, I want to add 1 new column in SortBy Column. Then i guess, automatically when search is called, this will work as per value selected in SortBy.
Yes. BAQ can be created for any new quick search requirement. But this requirement is of parameter in quick search. When you wil open Part Search, 1st parameter is SortBy. In that I want to add 1 more new column like say Description. Thats it.
Then when search will click, search result will come as per sorting selected in above parameter.
Mmm I don’t think there is a eay to customize the search form via any type of customization. I thinl you have 2 options:
A) perform the sort on a bpm post-process on the getrows. This would be a hardcoded sort
B) replace the search button and add your own search form using a popup form by removing all controls (you can use UD01). This form will only be used to capture the search and sort options. After this, execute the getRows and compose the filter and sort expression.
Not directly.
How many records are you hoping to show when you filter?
If the column is shown, you can click on the header to sort it. If it isn’t shown, I use this code to add more columns:
//add to switch statement in BeforeAdapterMethod
case "GetList":
case "GetRows":
System.Collections.ArrayList myCols = new System.Collections.ArrayList();
EpiSearchColumn col1 = new EpiSearchColumn("Key1", "Alloy Code", -1, true, 0);
EpiSearchColumn col2 = new EpiSearchColumn("Key2", "Common Tradename", -1, true, 0);
EpiSearchColumn col3 = new EpiSearchColumn("Key3", "UNS", -1, true, 0);
myCols.AddRange(new object[] { col1, col2, col3 });
for (int i = 0; i < myCols.Count; i++)
oTrans_adapter.SearchForm.SetEpiSearchColumn((EpiSearchColumn)myCols[i], true);
break;
Use the wizard to add the “BeforeAdapterMethod” code. Then add a switch statement inside it. Finally, use this code. Notice it is only for UD tables. You will need to change it for your table.
