When on a BPM you are going to add a using or reference the dialog to pick from the general existing assemblies takes forever to load.
Not only that but it doesn’t cache, so when you exit, if you have to go back in, it once again takes the same amount of time to load all the references.
Since this is the “standard” assemblies which don’t change very often (dare I say only on updates) why on earth is this not cached, and maybe the cache can be refreshed every time the app server recycles or when DataRegen is done
Pretty please with a cherry on top, for a guy whose job is to write BPMs and customizations 8 hours a day. This would be a huge time savings.
CC: @Rich
