Add RDD Report Criteria Prompts as invidual fields in SSRS RptParameter Dataset
It would be really helpful if when we Create SSRS Report in Report Style Maintenance Epicor would bring any RDD Report Criteria Prompts through as individual Fields under the RptParameter Dataset instead of putting them all together in a text string in the UserCriteria field. I would like it to work similar to the way that the BAQ Report Designer would pull the BAQReportParameters into Crystal.
Crystal Reports BAQReportParameters:
Thank you for any consideration in implementing this request.
