Arcadian
(Vilasack Phothisan)
July 3, 2018, 6:44pm
1
I am trying to add a quoteDtl programmatically. When I do an update I get this error:
The maximum number of characters allowed for Group is 8
I don’t see a “Group” field in the quotedtl object. What does this mean? What fields do I need to populate at minimum?
Maybe post some code so we can see what you’re talking about
Mike
(Mike Watkinson)
July 3, 2018, 7:14pm
3
Maybe your product group…QuoteDtl.ProdCode. Are you entering the description instead of the code?
Are you adding this via a BPM or UI Customization?
I’d tip my hat to Mike’s suggestion, but without the code like Aaron suggests, we dont have much to work on.
Arcadian
July 10, 2018, 8:43pm
6
Thanks for all the reply. It was a simple mistake on my part. I didn’t TRIM the string when I assigned it to the field. The extra white space caused it to go over the max limit.
