Add memo for a UD Table
I’m not sure how to run
protected override void LaunchMemoEditor()
It states “Script.LaunchMemoEditor(): no suitable method found to override”
Assuming that would link in to Ice.Lib.Framework.MemoHelper.LaunchMemoEditor - since the UD UI doesn’t have a class for it like I found others do
Though I did find on one of your (tomdomurat) previous posts for using a ProcessCaller.LaunchCallbackForm(oTrans,“Ice.UI.MemoEntry.dll”,memoArgs);
Which did open the form - but then I run into the “Can’t add rows” problem again.
I’ve tried changing the RelatedToSchemaName and SystemCode between ERP/ICE with no luck on adding the memo
Though with it on ERP I am able to go into the memo category entry and add in an entry for UD10
Additionally on directly adding in a memo row for UD10 - it has to go under RelatedToSchemaName = ‘Ice’ or it won’t show up.
Then when you try to update the row you get the error: “Record for update was not found by its SysRowID value”
This might just end up with me making my own “memo” screen out of a UD table but I’d like to avoid that.
