I’m facing "A similar process already running’ for multi-company direct server process. Please share the solution…
You either have a process stuck or your time to finish Multi-Company does not align with the time it should run again. Set your Multi-Company Process to run every 10 or even 15 minutes, if you set it to like every 1-5 minutes you may encounter that error since the previous one did not complete or it has crashed.
Increase your time and go restart your Epicor Task Agent.
Thanks for the update.
